Dear all,
iam working on a new project where i have to select piping for the below application:-
Project:Vent gas condensation
Stream :Solvent vapours
Solvent vapours from tanks,receivers,reactors & centrifuge vents will be connected to a vent gas condenser.Vent gas condenser maitains -ve suction pressure (with blower)
I have to select piping for the above application.
My choice is for ERW pipes(Class B or Class C) since the application is low pressure & low temperature.But sofar we have practised to use only seamless.
Kindly advice.
Bhaskaran
Erw Vs Seamless Pipes
Started by bhaskaran, Feb 24 2008 11:47 PM
Slope Of Flare Sub Headers / Tail Pipes And Main HeadersStarted by Guest_Sawsan_* , 02 Dec 2024 |
![]() Split Flow Between Two Pipes At RatioStarted by Guest_Abiodun1_* , 30 Oct 2023 |
Asme Certification For Water Pipes, RotorStarted by Guest_Orzelgorskiego_* , 13 Jul 2023 |
![]() Pressure Drop Calculation For Incompressible Fluid In PipesStarted by Guest_Arbaaz Shaikh_* , 21 Aug 2020 |
Erosion Velocity For Nonmetallic PipesStarted by Guest_SawsanAli311_* , 11 Nov 2019 |
