i am getting problems in slecting material for fuel gas having 40% CO2.
Design Pressure is 900psi and Design temp is 110F.
Can any body advice me wether the NACE complience will work or i have to go for SS?
Kashi
Material Slection For Co2
Started by Kashi, Mar 11 2008 02:47 AM
Posted 11 March 2008 - 02:47 AM
Posted 11 March 2008 - 07:56 PM
QUOTE (Kashi @ Mar 11 2008, 02:47 AM) <{POST_SNAPBACK}>
Kashi
Kashi
High CO2 in wet fluid would lead to severe corrosion for those material susceptible to acid carbonic corrosion... NACE MR 0175 compliance is required for sour service and combination of partial pressure & pH leads to Sulphide Stress Corrosion Cracking (SSCC). Don't see the relation between CO2 and NACE...
Screening Heat & Material Balances Cases For Fire Relief Psv SizinStarted by Guest_powerox6_* , 21 Aug 2026 |
Psv Body Material Of ConstructionStarted by Guest_QuantumEng_* , 07 May 2024 |
Material Balance With ReactionStarted by Guest_Kentucky08_* , 30 Apr 2025 |
Material Balance ProblemStarted by Guest_vinnay1999_* , 18 Oct 2024 |
Pipeline Material SelctionStarted by Guest_BabRafiq1_* , 06 Sep 2022 |
