I have this case where a distilled coconut fatty acid (DCFA) B1210 manufacturer claimed that the threaded region of the metal drum closure (pre-coated mild steel flange) was not properly coated with the protective coating layer (IP2088) hence cause their product to turn into brown residue on the the drum closure area when in contact with the exposed surface of mild steel. They alleged the brown residue formation was due to a reaction between their product and the mild steel of the flange. Is this phenomenone possible?
Thank you very much!
Distilled Coconut Fatty Acid B1210
Started by keverne, Mar 11 2008 03:15 AM
Posted 11 March 2008 - 03:15 AM
Posted 17 March 2008 - 10:42 PM
Actually, this sounds about right. I spent some time working for a fatty acid manufaturer, and we had many corrosion issues with carbon steel and in some cases even 304 SS tanks. We got to the point where, in fatty acid service, everything was 316L SS or higher metallurgy.
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Sulfuric Acid PlantStarted by Guest_Kartik54_* , 16 Mar 2024 |
Linear Alkyl Benzene Sulfonic Acid Production (Labsa) SimulationStarted by Guest_Emranm02_* , 03 Mar 2024 |
Sulfuric Acid Production / Partial Pressure Of H2So4Started by Guest_Jon K_* , 22 Sep 2023 |
Diluting Of Sulphuric Acid In Water Treatment Plant IndustriesStarted by Guest_YUMI_* , 15 Jan 2023 |
