Hi..I am also to design a packed column and I am wondering if it is advisable that I may use the HETP method to calculate the height of the column..
To Use Hetp Method Or Not?
Started by Helena_Ali, Apr 01 2008 10:57 PM
Posted 01 April 2008 - 10:57 PM
Posted 02 April 2008 - 08:23 AM
QUOTE (Helena_Ali @ Apr 1 2008, 06:57 PM) <{POST_SNAPBACK}>
I'm not sure what alternative you might consider. Certainly if you are modelling a process involving mass transfer across a packed column, you will have theoretical stages in your simulator and you must convert that to packing height in your design. At some point you will be converting Theoretical Plates to the packing Height Equivalent.
Doug
Posted 02 April 2008 - 09:52 AM
Helena,
Total HETP required for separation efficiency that you need to obtain by fractionating feed in the tower, is the actual height of structured (or random) packing that corresponds to the exact number of theoretical plates you calculated. There are no further details of your application, but in general - for the estimation of tower height - you need to take into account the following items:
- Number of packings
- Support grids below each packing
- Hold-down grids above packing
- Liquid distributors and redistributors
- Adequate height of tower sump and provision of sufficient space for reboiler return (if it is a reboiled column)
- Provision of sufficient space at all tower locations for maintenance reasons (collector trays, liquid/vapor distributors, packings etc.)
This is the minimum input data required for proper column design.
Posted 02 April 2008 - 11:07 AM
thank you for your help on this topic Zauberberg...
![]() How To Have 2 Property Method In Aspen Plus Based On Phase?Started by Guest_m.ghaziasgar_* , 21 Aug 2024 |
![]() Vertical Separators Best MethodStarted by Guest_fmalik_* , 02 Dec 2023 |
Hysys Packed Tower Design/sizing (Hetp)Started by Guest_Lolita21_* , 11 Oct 2021 |
![]() How To Interpret Hetp From Rate-Based Simulation?Started by Guest_victornassau_* , 17 Jul 2018 |
