Have problem with the coffee odor coming out of the roaster exhaust. Previous managers installed a wet scrubber using zeolite as adsorping medium. Plain water is being used to scrub and recirculated. For two months, the odor seem controlled, but it's back again. Need suggestions to improve. Air flow is 6000 cfm; packed tower diameter is 3.1 meters; zeolite height inside is 2 meters with size of 6" irregular shapes at the bottom and smaller sizes at the top.
Coffee Roaster Odor Removal
Started by Guest_Jonathan Bernardo_*, Mar 13 2004 01:17 AM
Posted 13 March 2004 - 01:17 AM
Guest_Liquid Scrubber_*
Posted 13 September 2004 - 12:59 PM
Have you tried adding a little caustic to your water? If your zeolite can handle the high pH, this should help with the odor. Also, you may be able to try activated carbon. In some cases (as in crushed coconut shells) the material cost can be downright negligible.
Removal Of Mosh/moah ContaminationStarted by Guest_DistillationChris_* , 16 Jan 2026 |
Moisture Removal From Blower AirStarted by Guest_Makarove_* , 12 Jul 2024 |
Co2 Removal Membranes Between Compressor StagesStarted by Guest_Sinclc_* , 26 Mar 2024 |
Carbon Filter Used In Hot Benfield Solution For Co2 Removal In AmmoniaStarted by Guest_Abhishek Taware_* , 14 Jul 2023 |
