Hi All,
I'm working for a natural gas utility. I was wondering if anyone has experience with oils slugs in natural gas distribution piping. The line is too small to pig, so field workers have been blowing off gas through a small drum to purge the line, but this is potentially dangerous and very messy. I have been researching into knock out drums and I want to size it down for portable use, possibly fitting it with a mist eliminator and a flame arrestor.
I've been using Souders and Brown calculations, but I am unsure whether it will be effective as a small portable unit. I have looked through many books, but none comment on small units.
Has anyone had a similar problem? or knows of a product/solution used in industry? Thanks.
Also, I'm having trouble finding a lighter weight flame arrestor. Do they exist? Cheers! Thanks for any help!
Dan
Removing Oil Slugs In Pipeline
Started by , Apr 15 2008 03:33 PM
No replies to this topic
Posted 15 April 2008 - 03:33 PM
Choosing The Right Type Of Evaporator For Removing Hcl From Aqueous SoStarted by Guest_anggara_* , 09 Feb 2026 |
Determining Pipeline Design PressureStarted by Guest_applepe_* , 05 Dec 2024 |
Energy Saving In Pump By Reducing Pressure Drop In Downstream PipelineStarted by Guest_Srinivas Agastheeswaran_* , 19 Nov 2024 |
Steam Condensate Pipeline Water HammerStarted by Guest_kaidlut_* , 06 Sep 2024 |
Achieving Ultra-Low Water Content (<0.1 Ppmv) For Pipeline PiggingStarted by Guest_Finchh_* , 21 Aug 2024 |
