Hi all,
I have a tank of water with very high concentrations of sodium chloride and sodium hypochlorite. The was is blow down water from a wet scrubber and packed tower. We typically evaporate the water and let the tank dry. As you can imagine, that is a very long process to dry the tank and usually we form a salt dome and have a large slug of trapped water. Then we go in the tank and dig out the salt.
During the evaporation process, the salt begins to precipitate out and form along the sides and bottom of the tank, thus becoming supersaturated.
Does anyone have any knowledge or experience with filtering this type of water (supersaturated) to remove the salt precipitate?
Salt Removal From Scrubber Water
Started by DougB, May 08 2008 01:16 PM
Posted 08 May 2008 - 01:16 PM
Posted 17 September 2008 - 05:25 PM
QUOTE (DougB @ May 8 2008, 01:16 PM) <{POST_SNAPBACK}>
Hi all,
Dear DougB,
I suggest that a basket centrifuge will serve the purpose of filtering out the precipitated salt at saturation point. You can estimate the amount of salt formed per shift and select the centrifuge with its solid handling capacity. ---- bmkhare,India
Posted 11 March 2009 - 06:45 AM
Hi all,
Can you further describe your process along with concentrations of salts at various stages
Posted 11 March 2009 - 11:33 AM
Reverse osmosis is sometimes used to remove salts from boiler water. It could have an application here but concentration may be too high.
Sour Water Handling And Treatment SystemStarted by Guest_rizwanogdc@gmail.com_* , 27 Aug 2026 |
Water Draw Off Arrangement For Condensate Stabilizer ColumnStarted by Guest_hirengdesai_* , 18 Aug 2026 |
"natural Gas Co2 Removal Via Membrane SeparationStarted by Guest_guoyinyanliner_* , 10 Jun 2026 |
How To Estimate The Water Dewpoint From Heat And Mass Balance Of NaturStarted by Guest_krishnnaa26_* , 30 Apr 2026 |
How To Handle Water Byproduct And Man Hydrolysis In The Dbp Solvent RoStarted by Guest_martzian_* , 20 May 2026 |
