....what are the required data to design the cyclone separator?!!!! OR what are the given data that we will design the cyclone upon it?!!!!
.....does it make a difference if the inlet cross section are is CIRCULAR or RECTANGULAR ?
Very Important Questions About Cyclone Separator (solid-gas)
Started by tarekmonier, May 10 2008 10:09 AM
Posted 10 May 2008 - 10:09 AM
Posted 12 May 2008 - 04:11 PM
flowrate, particle size distribution on inlet, efficiency required (can be defined in many ways), allowable pressure drop... question is very general, therefore answer is general too
yes, it does
inlet to cyclone is rectangular and "higher > width" to feed cyclone close to the wall to minimise the average distance the particles must travel to be removed from gas stream
yes, it does
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
Gas-Liquid Separator Design With CondenserStarted by Guest_shambola_* , 16 Jan 2025 |
![]() Types Of Cyclone Function In Large Flow RateStarted by Guest_alaasleem2026_* , 03 Sep 2024 |
![]() Discharge Scrubber And Suction SeparatorStarted by Guest_Falah_* , 21 Jul 2024 |
