I understand that Vessels are normally specified for full or partial vacuum to allow for steam out operations.
However, I wish to know if this requirement is also a requirement for piping, valves and instrumentation as well.
Thanks.
Specification Of Piping For Full Vacuum
Started by chizonweke, May 12 2008 05:22 AM
Posted 12 May 2008 - 05:22 AM
Posted 12 May 2008 - 05:40 AM
The piping, isolation valve (ist isolation valve from vessel) normally sees the steam out condition & hence need to be designed for steam out condition . Instruments like Level Transmitter, Pressure gauge etc need not be designed for steam out condition as they can be isolated during steam out with the isolation valve provided at inlet. If a instrument can not be isolated /removed during time of steam out then only it needs to be designed for such condition ( i doubt if any one does so) .
Vinay
Vinay
Posted 12 May 2008 - 12:48 PM
QUOTE (vinay @ May 12 2008, 05:40 AM) <{POST_SNAPBACK}>
Vinay
Vinay
There is potential of valve leakage or passing. I doubt credit should be taken for valve isolation.
Posted 13 May 2008 - 11:48 PM
Dear Joe,
Steam out of vessel is done by isolating & blinding all the other nozzles of the vessels apart from Vent ( which is open) & the steam inlet nozzle. Blinding is also essential if the vessel is to be man entered. As the blind is present after 1st isolation valve all the downstream piping after the valve need not be designed for full vaccum . Again the philosophy can be different in different companies.
Vinay
Vinay
Posted 15 May 2008 - 01:41 AM
QUOTE (vinay @ May 14 2008, 12:48 AM) <{POST_SNAPBACK}>
Dear Joe,
Vinay
Vinay
I have limited experiences in such service but i have the following question. Maybe an experience engineer in operation can assist :
Should you open the nozzle, put the blind in place, then conduct steam out ?
I guess if you can follow above sequences, then probably you are right.
OR
all the nozzle isolation valves the special type arrangement (can't remember the name) where you have double valving with spade/blind and purging nozzle in it.
I guess if above arrangement is provided, then probably you are right.
![]() Vacuum SystemStarted by Guest_panoska_* , 21 Oct 2024 |
![]() Vacuum Getting Disturbed Periodically In Vacuum UnitStarted by Guest_aka28_* , 08 Oct 2024 |
Maximum Velocity For Piping In Fire Water Distribution System (Fire WaStarted by Guest_applepe_* , 06 Sep 2024 |
Pressure Drop In PipingStarted by Guest_Jaldhipatel_* , 05 Jun 2022 |
