Using Excel In Problem Solving
#1 Guest_Universal Engineer_*
  • guestGuests
Posted 06 June 2008 - 08:35 AM
Hello members,
I am a new member in the ChE forums and I need your help please:
I need to know what are the basic excel functions that a 4th year chemical engineering student needs to know? What should I practice in excel to help me in problem solving?
Thank You
UE
Posted 11 June 2008 - 10:12 AM
Universal:
My first and foremost comment to you is that, as a 4th year chemical engineering student, you are starting in on Excel far too late. In my opinion, you should have started to use Excel for all your problem solving in school assignments during your first year of University and should have started in on Visual Basic programming (as it applies to Excel) during your second year. But, what is done is done and we can't turn the clock back. Just be reminded that you are starting very late and should accelerate your Excel learning and practice.
The Excel functions you should know and MASTER are all in the Excel program. As a 4th year student, you should know perfectly well what functions are the most important and for what reason. All you have to do is dig in and start using Excel in your problem solving. Basic stuff such as the Trig functions and the Boolean algebra are self-explanatory. So are the Horizontal and Vertical Lookup functions. This material is "self-evident" to anyone who has done his/her share of Chemical Engineering problem solving in such classes as Material Balances, Unit Operations, Heat Transfer, Fluid Mechanics, and Thermodynamics. For examples on how professional Chemical Engineers use Excel spreadsheets in their everyday problem solving, all you have to do is read our responses in these Forums and download all of the Excel Workbooks we have uploaded for your education and enjoyment. Let your fingers do the walking through the SEARCH feature and you will find enough Excel material to keep you busy for years. Start by studying how I solve the Crane Tech Paper #410 Example Fluid Flow problems. You can download this workbook right now from the #1 thread in this Student Forum.
I hope you are serious and strive to catch up with your competitive student companions in Chemical Engineering.
Good Luck.
#3 Guest_Universal Engineer_*
  • guestGuests
Posted 13 June 2008 - 04:02 AM
Art Montemayor,
First of all, thank you for the reply...
Actually I use excel as well as Aspen Plus in problem solving..
This is not my first time using Excel..
I asked that because I am about to graduate and I want to make sure that I am on the right track regarding using Excel in problem solving...
I will download the files for practice.
Thanks for the help
UE
#4 djack77494
djack77494
  • 1,282 posts
Posted 16 June 2008 - 05:22 PM
UE,
I daresay that Excel and other spreadsheets are the Number 1 tool for all engineers, exceeding even the utility of specialized software such as simulators. Given a choice, I'd quickly give up my simulators to keep Excel, and I think most other engineers would do the same. If you remain technical, you'll be constantly using Excel (or its competitors).
#5 Profe
Profe
  • 316 posts
Posted 18 June 2008 - 10:41 AM
Hi Universal Engineer
About the Excel to solve Chemical Engineering problems, try the next link: http://azkef.org/ChE...XCEL basics.pdf
I think that will be useful to start.
#6 katmar
katmar
  • 689 posts
Posted 18 June 2008 - 11:08 AM
Two features which I have found useful are multi-variable linear regression and goal seek. Goal seek is very useful in situations where you have some very involved correlation that predicts something like a heat transfer coefficient and one of the variables is the baffle spacing. You can use goal seek to find the the baffle spacing that gives you the required HTC - its much easier than having to rework the correlation into the alternate form.
But to really get the most out of Excel you will have to master macros and a bit of Visual Basic for Applications (as I think Art already suggested?).
Good luck.
#7 Guest_Universal Engineer_*
  • guestGuests
Posted 19 June 2008 - 12:56 PM
Thank you all for your useful replies...
I really do appreciate it
UE
