i am trying to determine if it is better to have laminar or turbalent flow for my system.
i have a hot material (nylon 6) that needs to be cooled. so i will have a jacketed wall (heat exchange plate) that will have water running through it.
should i use dimensions that will result in laminar or turbalent flow?
also, i am having trouble finding a simple equation to use that involves laminar flow in order to calculate my reynalds number.
thanx!
Heat Transfer
Started by ColorMan, Jun 20 2008 09:10 AM
Posted 20 June 2008 - 09:10 AM
Posted 21 June 2008 - 01:07 PM
To Find out the nature of flow, calculate the Reynolds Number from this Equation.
ReN=Mass of fluid X Dia meter of pipe/viscosity of that fluid
after calculating the Reynold number then you will be able to know about the nature of flow and for 2nd part of your question let to explain by some expert.
Posted 23 June 2008 - 07:25 AM
i understand how to determine whether it is laminar, transitional, or turbalent flow.
i am looking to determine which one results in optimal heat transfer when using water.
Posted 23 June 2008 - 08:07 AM
in most cases (all?) the turbulent flow results in higher heat transfer coefficients... but it also requires more energy (higher flowrate) to pump water through the same geometry
Posted 23 June 2008 - 08:33 AM
thanx for the reply andre.
so turbalent flow is what i'll go for.
know i am going to have a series of vertical plates that the water will be flowly through. the water will enter in the bottom of the plate, and exit the top.
my issue is that the characteriskic length is too large, which creates issues of me having turbalent flow.
i have 2 options.
1. if i have my heat exchange plates with only baffles inside (about 5) I will have to raise my pump to 80+ GPM.
2. or i could make a U-shaped path inside of the plates that will control where the water is able to flow. i can have a smaller pump in this case, but.... how will this effect my surface area?
normally the surface area would just be the height*width as in case 1, but in case 2, there seems like there would be less since the water will not be able to touch every aspect of the plate, and instead only the part where its tube is. so would i just use the surface area for the U-shaped tubes inside the heat exchange plates?
i have 2 options.
Posted 26 June 2008 - 05:45 AM
Hi ColorMan,
You mentioned that you have to cool Nylon. Is it in molten form or is it a solid ? Cooling of polymers can be tricky. For example if you cool a polymer melt with cooling water the polymer will solidify at the heat transfer surface blocking all heat transfer. In fact the colder the cooling water the worse the problem.
Please describe the system to get more meaningful assistance.
Guest_majster_*
Posted 29 June 2008 - 02:17 PM
Hi ColorMan
here you can find equations to calculate heat transfer coefficient for various geometries and flow conditions:
http://www.cheresour...onvection.shtml
As Andree said, flow regime you will use, is compromise between area of heat transfer surface and power needed for coolant pump. Higher velocities of coolant will result in higher heat transfer coefficient and smaler heat transfer surfaces and in higher pressure drops and higher pump power requirments (and larger and more expensive pumps).
Best regards
Majster
Best regards
Majster
Heat Of Dilution Of Hydrogen Chloride In Hydrochloric Acid Solution (3Started by Guest_fredlan54_* , 21 Nov 2025 |
Shell And Tube Heat Exchanger In HtriStarted by Guest_Sanjayr126_* , 28 Sep 2021 |
Heat Loss Calculation From Cylindrical Tan;Started by Guest_rasprocess2026_* , 23 Jul 2025 |
