hey everyone..
i need to add a reboiler and a condenser in hysys, however, i do not have the icons. may i know how do i add an extension to the hysys so that i have reboiler and condenser?
thanks!
Hysys
Started by missyabarai, Jun 27 2008 11:37 PM
Posted 27 June 2008 - 11:37 PM
Posted 28 June 2008 - 12:37 AM
Dear,
What you want is not clear enough. I hope that you want to put a condenser and reboiler in Main PFD Environment and not in column Environment. In this case you can use the Shell and Tube Exchanger Icon. In column environment you have options as partial condenser/total condesner and a kettle type reboiler. If you thermosyphon reboiler you can model it as built in the column environment.
Please let me know still any query remains ununderstood. Waiting for your reply.
Posted 01 July 2008 - 08:25 AM
Reboiler (kettle type) and condenser (total, partial, full reflux) are standard items in distillation column template. Once when you double-click on the distillation column in the main flowsheet, choose button "Column environment" in the column window. This will transfer you to the column sub-flowsheet, where reboiler and condenser are shown as separate unit operations.
If you need to model different type of reboilers (recirculating thermosyphon or once-through), choose refluxed absorber template and configure bottoms stream together with separator, tee, mixer and heat exchanger (actually your reboiler) in such manner it reflects the true column/reboiler configuration.
Hysys Stream WorksheetStarted by Guest_nasim304_* , 22 May 2024 |
Aspen Hysys Dynamic Mode Compressor ShutdownStarted by Guest_Arta901_* , 21 May 2024 |
Aspen Hysys Simulation IssueStarted by Guest_Karim kimo_* , 20 May 2024 |
Aspen Hysys Training Opportunities For Six Individuals Within Our InduStarted by Guest_Hafiz_Che_* , 30 Apr 2024 |
Need Help On Hysys - Valve Opening Vs Valve CvStarted by Guest_marcoz1121_* , 19 May 2024 |
