Hello All,
I'm currently modelling a flow station with feed streams from multiple wells/reservoir, I xterized d well fluids adn i wish to transfer all of them into a single case file for me to use them. Is this possible and how can I go about it.
Your help will be highly appreciated.
Using Streams Across Multiple Hysys Case
Started by blinx4real, Jun 30 2008 09:14 AM
Posted 30 June 2008 - 09:14 AM
Posted 30 June 2008 - 10:42 AM
If I understood you well, you can combine all these streams and unit operations into sub-flowsheet. Select the area you want to transfer into sub-flowsheet, right-click mouse button and choose "Combine into sub-flowsheet".
Posted 30 June 2008 - 03:37 PM
QUOTE (blinx4real @ Jun 30 2008, 10:14 AM) <{POST_SNAPBACK}>
Hello All,
I understood you have stream (well) composition and properties from multiple HYSYS files and you would like to transfer them into one HYSYS file...you may use the XML Data Exchanger capability. Detail procedure described in "Transfer Stream or Unit Operation Properties From Hysys File to Another Hysys File"
Posted 01 July 2008 - 03:37 AM
thanks a lot, that was most helpful. It would have been quite tedious to have to enter the parameters one after the other.
Posted 12 July 2008 - 07:45 AM
Dear,
While using xml application make sure that the two cases have a similar settings in Simulation Basis Manager
Posted 20 July 2008 - 07:58 AM
yes thats true, what I did is to first import the basis package into the new case and then use the xml fucntionality to transfer the stream properties, this worked quite well.
Posted 21 July 2008 - 08:04 AM
Dear,
Yes you are right. Always work with a saved fluid package if you are performing the similar model simulations. This will not have any discrepency as the Simulation basis manager will have the same settings like list of components and the changes you made like Enthalpy calculations method and all. Then you will not have any problem for import and export cases through .xml.
![]() Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , Yesterday, 01:41 AM |
![]() Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
