We decided to design a Flare Gas Recovery System for a refinery. The flare gas includes:
Component H2 C1 C2 C3 C+4 H2S
Mol% 43 10 30 2 10 5
Temperature 80°C
Pressure 1 bar
Flow 630 kg/hr
A flare gas recovery system has been designed but we need to seperate H2 from the recovered gas. Would you please advise me how I can separate hydrogen economically from this stream?
Thanx
Hydrogen Recovery From Flare Header
Started by Guest_rahimi_*, Jul 06 2008 12:41 PM
Guest_rahimi_*
Posted 06 July 2008 - 12:41 PM
Guest_shanesheoran_*
Posted 19 July 2008 - 10:56 PM
QUOTE (rahimi @ Jul 6 2008, 12:41 PM) <{POST_SNAPBACK}>
Temperature 80°C
Pressure 1 bar
Flow 630 kg/hr
Thanx
Temperature 80°C
Pressure 1 bar
Flow 630 kg/hr
Thanx
Hi Rahimi
Try PSA system. It is simple. But your pressure is 1 Bar, which is too low for PSA system. You need to boost the Pressure to a Minimum of 8 Bar or so.
Also you need to Condense and Remove All Mosture before it enters PSA system.
Good Luck
Acidic Condensate In Sulphate Recovery By Vapour SeparationStarted by Guest_Ranga v_* , 09 Nov 2025 |
Heat Of Dilution Of Hydrogen Chloride In Hydrochloric Acid Solution (3Started by Guest_fredlan54_* , 21 Nov 2025 |
Flare Header Reverse FlowStarted by Guest_Ahmadhamzahperta_* , 04 Apr 2025 |
