An update for DWSIM 2.1 for Windows, Linux and OS X was released. The following is the list of changes since Build 4503:
Version 2.1 Build 4606
- [CHG] COSMO-SAC database loading is now done only on-demand instead of during startup (Windows only)
- [CHG] Petalas-Aziz pressure drop model now uses a native library by the authors (Windows only)
Version 2.1 Build 4605
- [NEW] Simultaneous Adjust Solver
- [NEW] Added the option to edit pure compound properties through the Pure Compound Properties utility
- [NEW] Added automatic calculation of PR and SRK Peneloux volume translation (shift) coefficients for pseudocomponents
- [FIX] Several fixes to the Pipe Segment (and pressure drop) model, includes Joule-Thomson cooling option
- [FIX] Fixed drawing of Adjust's line connectors
Version 2.1 Build 4602
- [NEW] Added Peneloux volume translation support for PR and SRK Property Packages (Configure Property Package > General Options > Use Peneloux Volume translation => set to 1)
- [FIX] Fixed material stream composition editing in commmand line mode
- [FIX] Fixed ambient temperature not being set on Thermal Profile Editor (Pipe Segment)
Version 2.1 Build 4589
- [CHG] Enabled calculation of material streams when there is no mass/mole flow
- [FIX] Fixed mixer calculation when some of the inlet streams have no flow
- [FIX] Fixed a bug with the mass balance in the gas-liquid separator
Version 2.1 Build 4569
- [NEW] Save/Restore simulation states
- [NEW] Capture flowsheet snapshot and send to clipboard
- [FIX] Fixed command line run mode
- [FIX] Fixed heat capacity coefficients generated by the Compound Creator
- [FIX] Minor fixes to petroleum charact. utilities
Version 2.1 Build 4534
- [FIX] More fixes and enhancements to the flash algorithms
- [FIX] Fixed a bug in the excel interface
- [NEW] Added "reset settings" functionality by pressing Shift during startup
Version 2.1 Build 4526
- [NEW] Added Lua scripting support
- [FIX] Further fixes and improvements to the flash algorithms
- [FIX] Fixed ChemSep column operation with pseudocomponents/hypotheticals
- [FIX] Fixed Zc/Vc calculation for pseudocomponents
- [FIX] Fixed some bugs in the CAPE-OPEN Thermo interfaces
Version 2.1 Build 4513
- [FIX] Enhanced stability and reliability for Pressure-Enthalpy flash calculations
For more details and links to installer, docs and tutorials, go to http://dwsim.inforside.com.br
Thanks,
Daniel
Edited by DanW, 11 August 2012 - 04:32 PM.
