hello
i am m.tech student in peocess equipment design. i want to know how to calculate the diameter of shell-side and tube-side nozzle for shell-and-tube heat exchanger, because calculation of shell-side and tube-side pressure drop accounts for pressure drop in nozzles too. the pressure drop through nozzle depends upon the fluid velocity through nozzle and which depends on diameter of nozzle. can any one give guidelines plz
Shell-side And Tube-side Nozzle Diameter
Started by Anil Panchal, Jul 21 2008 01:04 AM
Posted 21 July 2008 - 01:04 AM
Posted 22 July 2008 - 08:33 AM
Anil,
Besides raw pressure drop, there is often a concern over the fluid's momentum upon entering the exchanger. Fluid impingement on the tubes can lead to unacceptable erosion. This may be handled by impingement plates, but limiting momentum - e.g. the rho * V^2 term - is also a common practice.
![]() Rotated Triangular Tube Layout Vs Triangular Tube LayoutStarted by Guest_Heat Transfer Novice_* , 28 Sep 2024 |
![]() Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
![]() Tube Rupture ReliefStarted by Guest_felderosfelder101021_* , 16 Jan 2025 |
Maximum Mass Flow In A Shell & Tube Heat ExchangerStarted by Guest_DonStalke_* , 22 Sep 2024 |
![]() How To Use Shell Thermia B Oil In Hysys/ AspenStarted by Guest_sportybk_* , 24 Jul 2024 |
