Hello all,
I want to know if 35# condensate from a heat exchanger returing after a trap can be routed to another heat exchanger operating @ 150/175 # operating pressure using gravity flow.
Also I would like to know if anyone has any material on sizing the condensate return lines.
Condensate Return Lines
Started by bios16, Aug 15 2008 01:43 PM
Posted 15 August 2008 - 01:43 PM
Posted 15 August 2008 - 02:00 PM
Hi Bios16,
Though unable to help you ... but I guess - the following quoted text would help someone seeking you an answer.
Thanks,
Thanks,
QUOTE (bios16 @ Aug 12 2008, 02:11 PM) <{POST_SNAPBACK}>
I need to size condensate lines: I have 35 psig steam @ 150 deg C flowing through a 2"line (~1700 lb/hr) condensing in a plate and frame. The condensate is flowing out through a thermostatic steam trap to atmosphere. I need to size the condensate line coming from the HE to the trap and the line going to the trench.
Also another condenstae line having the same conditions joins this before going to the process trench. Please let me know if there any material. I have solved the problem almost 3/4 through. I found a condenstate line sizing chart. But I just want to verify my cals. Thanks
Posted 16 August 2008 - 12:27 AM
Search for the web sites of Armstrong Steam and Spirax-Sarco. They both have good technical information available. Or call in your local representative of either of these companies. They will most likely be happy to help, or to provide you with helpful literature.
Acidic Condensate In Sulphate Recovery By Vapour SeparationStarted by Guest_Ranga v_* , 09 Nov 2025 |
Reboiler Necessity For Condensate StabilizationStarted by Guest_Ammart42_* , 11 Oct 2025 |
Foam System Criteria For Hc Condensate Storage TanksStarted by Guest_Haideri_* , 28 Oct 2025 |
Sizing Of Condensate Return VesselsStarted by Guest_panoska_* , 23 Oct 2025 |
