Equivalent Length Resistance Of Valves And Fittings
#1 Bayo Alabi
Bayo Alabi
  • 26 posts
Posted 22 August 2008 - 05:38 AM
Hi
I am trying to calculate the resistance coefficients (K) and/or equivalent length resistance (L_e) of valves, bends and some other ‘uncommon’ fittings (e.g. flow indicator, concentric reducer, weldolets, 90o pulled bends, diverging siamese tee, etc.) in flow lines.
The fluids flowing separately in different lines are:
1. Produced water
2. Slurry (i.e. produced water containing small amount of sand).
I have the data for valves and common fittings from “Technical Paper #409” and
“Technical Paper No. 410”, both from Crane Co.
My questions and worries are:
1. Should I include ‘uncommon’ fittings in the K or L_e calculations?
If yes, where can I find the data?
2. Where can I find industrial standards in the area of line sizing for the following cases?
i. slurry line sizing
ii. partially-filled pipe lines
iii. gravity-induced flow (e.g. condensate flowing vertically down from a vessel to a storage tank)
3. Which method is preferred - K factor or L_e?
I will appreciate relevant contributions.
waa15
Posted 22 August 2008 - 06:05 AM
waa:
A concentric reducer is NOT an “uncommon” fitting. Rather, it is a COMMON fitting. So is a weldolet, and a 90o elbow. I never heard of a “pulled bend” or a “diverging siamese tee”, so I don’t know what they are. I thought I had heard of every conceivable fluid flow fitting by now.
You ask:
“1. Should I include ‘uncommon’ fittings in the K or L_e calculations? If yes, where can I find the data?”
I don’t know. What kind or type of calculations are you referring to?
You find “K” or Le values in manufacturer’s or supplier’s catalogs. I have found all I need in the Internet.
I have posted various Excel workbooks with Fluid Flow data and information in these Forums in the past. Have you used the SEARCH engine?
P.S. I think Einstein said, "The important thing is to not stop questioning".
#3 Andree
Andree
  • 140 posts
Posted 22 August 2008 - 06:43 AM
http://www.cheresour.../eqlength.shtml
hope this helps
#4 Bayo Alabi
Bayo Alabi
  • 26 posts
Posted 25 August 2008 - 05:57 AM
Andree:
Thank you for the link. I have carefully read the article and learnt some interesting things.
Art:
I thank you also for your time. In my first question, I was referring to calculation of L_e. By the way, we have chosen the L/D method.
I have also found interesting links on line sizing on the internet. However, I should by grateful if you can list some additional articles out there worth reading or links worth checking if you have them handy.
Warm regards
waa
#5 mangal
mangal
  • 5 posts
Posted 11 August 2009 - 07:01 AM
Hi
I am amit mangal from india....
I required the Crane Co.,technical paper no. 410,'flow of fluid' for finding some flow corelation for tube rupture case in heat exchanger..if u have the paper please send me..
and if u have some more material related to this article please send me....
it will helpme lot.
thanks & regards
amit mangal
#6 gvdlans
gvdlans
  • 619 posts
Posted 11 August 2009 - 07:23 AM
QUOTE (mangal @ Aug 11 2009, 02:01 PM) <{POST_SNAPBACK}>
You can buy your own legal copy via http://www.flowoffluids.com/tp410.htm
