Lock Open And Lock Close Valve Positions
#26
Posted 16 September 2008 - 02:38 AM
Anyway, this thread is a bit draged. As i mentioned earlier, there is not YES or NO for LC/CSC the blowdown line in general but specific case may be. Hope this can call it a stop.
#27
Posted 02 March 2009 - 08:55 PM
az locksmith
#28
Posted 03 March 2009 - 01:32 AM
Hello/Good Afternoon,
May I humbly suggest to open a new thread;since otherwise we are in a way might be going back to square one again.
Hope you do realize/appreciate.
Best regards
Qalander
#29
Posted 18 July 2012 - 02:19 PM
#30
Posted 14 April 2013 - 01:40 PM
When you've established the most appropriate process method for your application, you may need assistance selecting locking products for manual valves.
The right valve lock device depends on the nature of the service and the criticality of the valve isolation. A car seal, as the name suggests will seal the valve in a set position. But once you cut the cable to remove it, it's destroyed. If you need a reusable device a valve lockoff might be more suitable, fixed in place with a padlock.
And if valve control, especially when isolating safety relief valves is super-critical, a valve interlock could well be the way forward.
How To Size A Presure Equalization Line For A 10" Pipeline ValveStarted by Guest_Rerrizftt_* , 14 Jul 2026 |
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Minimum Distance Between Blowdown Valve And Cold Vent Outlet In A HighStarted by Guest_AMINEBELAL_* , 15 May 2026 |
Sizing Fire Case Relief Valve Installed Below Liquid LevelStarted by Guest_processrock_* , 14 Apr 2026 |
