Dear all
While doing Knock Out drum sizing through
1. Shell DEP we have to check whether its meeting De Foaming criteria or not by using a separate formula
2. API spec 12 J specify different residence times for foaming crudes
my questions are
1. How do we know whether feed having a foaming tendency or not
2. can we predict the foaming tendency in HYSYS/APSEN PLUS/PRO-II softwares
3. what are the fundamentals behind foaming
Thank you
Satish
Foaming In Knock Out Drum
Started by Srikrishna Chaitanya, Aug 26 2008 11:11 PM
Posted 26 August 2008 - 11:11 PM
Posted 27 August 2008 - 09:19 AM
The best way to confirm if given service is a foaming one, is to look for the references of similar plants and applications. If possible, conducting laboratory tests can be of much help.
Simulation softwares cannot provide such information - at least from what I have seen so far - and this is quite reasonable to be expected: simply, too many factors are involved. For example, applying foaming factor in design of fractionaton towers is an experience-based rule of thumb, resulting from hundreds or thousands columns where flooding has been observed well below design capacity.
The presence of solids induces foaming - you'll observe it if you put small amount of salt in a boiling water. High pressure operation also induces foaming. Agitation, presence of surface active agents etc.
Posted 28 August 2008 - 11:25 PM
Dear Zauberberg
Thank you very much for the reply
is there some literature available on this foaming ?
I have tried through GOOGLE but haven't got much
Posted 29 August 2008 - 12:06 AM
I believe it's hard to find any information related to foaming phenomenon, unless the subject (plant, application, service) is known. What causes foaming is the same in all these cases - as written above. The difference comes from the process/equipment type itself i.e. whether we are speaking about amine/glycol contactors, high pressure separators, 3-phase systems, distillation towers etc. In each of these systems foaming is caused predominantly by one of those factors which I mentioned before. Looking at the specific process application, you'll be able to narrow down the list of possible culprits, and find a way to mitigate or eliminate them.
![]() Blowdown Ko DrumStarted by Guest_Ade24_* , 13 Sep 2024 |
