hi/ everybody,
i have following problem with aspen plus while simulation run or while plotting
Processing input specifications ...
****TERMINAL ERROR
ACCOUNT-INFO PARAGRAPH MUST BE SUPPLIED
* ERROR SEVERITY LEVEL OF 0 IS <= ABORT LEVEL OF 0 *
* EXECUTION IS TERMINATED: SIMULATION WILL NOT BE EXECUTED *
what is exaactly mean that
how can i solve this problem
About Aspen Plus
Started by sacc, Aug 31 2008 06:59 AM
Posted 31 August 2008 - 06:59 AM
Posted 31 August 2008 - 12:30 PM
SACC:
Are you the Legal, Registered owner of the Aspen Simulation program you are running?
If you are, then simply pick up the phone and register you query with Aspen. If you paid them the thousands of dollars the program is worth, then the least you deserve is their dedicated service and care - which they furnish to all their PAYING customers.
If you are not (& neither is the person(s) who loaded the program on the PC you are using), then you have no business trying to operate a pirated software program. Which are you?
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
No Liquid Phase In Aspen PlusStarted by Guest_PengRobinson_* , 09 Feb 2025 |
![]() Help On Simulation Of Reactor In Aspen PlusStarted by Guest_m.ghaziasgar_* , 06 Jan 2025 |
