Isentropic Exponent For Hydrocarbon Gas
#1 palaniappan
palaniappan
  • 3 posts
Posted 04 September 2008 - 12:50 AM
How to get the value for isentropic exponent for a HC gas (Fuel gas)
I need this to find out the CV of a valve in the line for a vapour line using the online calculator in the following website.
http://tierling.home.texas.net/
Can any1 help on this.
#2 latexman
latexman
  • 1,816 posts
Posted 04 September 2008 - 08:44 AM
If the properties of HC gas (Fuel gas) can be accurately characterized by the properties of methane (CH4), I'd use k = 1.32 per Crane TP410.
If not methane, what other component can accurately characterize your HC gas (Fuel gas)? If a single component cannot be used to characterize your HC gas (Fuel gas), then you'll need to use mixture calculations and the problem just got 10 to 100X harder.
#3 palaniappan
palaniappan
  • 3 posts
Posted 04 September 2008 - 09:51 PM
QUOTE (latexman @ Sep 4 2008, 07:14 PM) <{POST_SNAPBACK}>
Thank you Latexman,
The FG basically composes more of methane .
#4 JoeWong
JoeWong
  • 1,223 posts
Posted 08 September 2008 - 03:19 PM
If your fuel gas can be properly characterized by EOS i.e PR, SRK, etc..., you may consider to use expander module in any simulator i.e HYSYS, PRO-II, etc by setting the isentropic efficiency being 100% with minor pressure drop...
