Dear Gents
I will be very appreciated if you help me to find...
1- during propane treatment (mercaptan removal) we use caustic 15% ,what will happen if we use more concentrated caustic (20% , 40%,...) ?
2-after washing propane with caustic it goes to another drum which contact with fresh caustic 7% , why 7%? (Before contacting, it passes a heat exchanger to increase its temperature up to 70C and 10% of COS would be extracted in this section.
I look forward for your kind reply
Thanks and Regards
Mercaptan Removal
Started by campiloo, Sep 08 2008 11:42 AM
Posted 08 September 2008 - 11:42 AM
Posted 10 September 2008 - 10:00 AM
campiloo,
It seams to me you are using two stage caustic wash. Here are my answers:
Question 1: Using more concentrated caustic solution is only affecting the quantity of caustic entrained from that stage and supposed lost in the subsequent water wash phases.
Question 2: It is a little strange to me to see a lower caustic concentration in the second stage, I would expect to be higher than the first stage. What is done usually is ensuring a certain constant driving force for the wash process by contacting high mercaptane concentration gas with low caustic solution and low mercaptane gas with high caustic composition, a kind of countercurrent process.
Heating at 70ºC is related to hydrates formation, I think one of the hydrates formes at 63ºC, and that's why heating is required.
I hope these helped. You can find more in GPSA Engineering Data Book, Section 21-Hydrocarbon Treating.
Posted 10 September 2008 - 11:40 AM
Hi
Thanks for your Reply
in 2nd stage which is called finishing drum , in order to get rid of all cos left(10% of initial content in the feed), the propan is heated at 70 C before entering the caustic finishing drum , actually the reaction with caustic solution must be complete and it can be done at a higher temperature (about 70 C)
this caustic finishing drum is operated on liquid counter current mode : sour fresh feed is introduced at its bottom level , while fresh caustic solution (7%wt NAOH average ) is continuosly injected at its top level under contrl flow
so the reason of 70C is Clear but why caustic 7%?
Posted 17 November 2008 - 11:00 AM
campiloo,
7% isn't a magic number. It's a balance between the availability of NaOH to neutralize acid gases, specific gravity difference to separate bulk hydrocarbon/aqueous phases, what is the maximum concentration of salts in solution before you stabilize emulsions and cause aqueous phase carryover, etc. If you want to use a higher concentration of caustic, go ahead and try. Just keep an eye out for aqueous phase carryover and ensure that you are avoiding caustic embrittlement concerns.
Moisture Removal From Blower AirStarted by Guest_Makarove_* , 12 Jul 2024 |
Co2 Removal Membranes Between Compressor StagesStarted by Guest_Sinclc_* , 26 Mar 2024 |
Carbon Filter Used In Hot Benfield Solution For Co2 Removal In AmmoniaStarted by Guest_Abhishek Taware_* , 14 Jul 2023 |
H2S Removal From BiogasStarted by Guest_Aliceat2000_* , 24 Jul 2022 |
