I have a gas flow under Standard Conditions but I need it at some specific T and P. How can I do to convert it automatically in Hysys?
Note: I automatically retrieve the gas flow with Visual Basic and insert into the inlet stream.
Regards.
Automatic Standard Conditions (t,p) Conversion
Started by Guest_Vitor Andrade_*, Sep 11 2008 11:30 AM
Posted 11 September 2008 - 11:30 AM
Posted 11 September 2008 - 06:27 PM
Your question is not clear...
You have a stream with composition at standard conditions. This will define all the necessary properties of your stream.
Now, you want the stream at P & T... isn't just change the P & T in the stream as you wish ?
May use the BALANCE operation unit for automation...
Posted 12 September 2008 - 05:57 AM
Why can't you do it directly, by specifying desired P, T parameters to the stream? Or using "Mole Balance" operation, as suggested by Joe?
Posted 12 September 2008 - 09:05 AM
QUOTE (Vitor Andrade @ Sep 11 2008, 10:00 PM) <{POST_SNAPBACK}>
Regards.
Regards.
Dear,
If you have the gas flow at STP and you need to calculate it (I interprete from your post that you need just flow and not the properties) at some T and P. Then why you need Hysys? If your interest is to say the properties at different T and P of the Gas apart from just flow then you can define a stream say by name A giving your STP condition and the gas compositions and you can find all the intrinsic properties for the stream at STP and once you give your flow value it will converge your stream. Now you can put the Balance Operation which is under logical operations category to update the required conditions from the stream A by checking the right parameter (here should not use mass and heat or mole and heat balance options). And you can change T and P and see the effect of these variations on your volumetric flowrate and the properties of the new streams.
Applicable Standard For Ethane Import And Regasification TerminalStarted by Guest_bisen1986_* , 19 Nov 2024 |
Lng Regasification: Heat Exchanger Operating ConditionsStarted by Guest_wangdee.s_* , 17 Nov 2024 |
Coefficient Of Conversion Of Electrical Energy Into Thermal Energy ForStarted by Guest_amx_* , 03 Apr 2024 |
![]() Fan Laws For Centrifugal Compressors And Varying Suction ConditionsStarted by Guest_SickPuppy0_* , 25 Jan 2023 |
![]() Standard ConditionsStarted by Guest_panoska_* , 06 Mar 2022 |
