Surge Analysis In Hysys
Started by SeanK, Sep 16 2008 01:33 AM
7 replies to this topic
Posted 16 September 2008 - 01:33 AM
Hi to All,
could anyone please guide me how to work with HYSYS for compressor surge analysis
any comments on the above would be highly apreciated
Seank
Seank
Posted 17 September 2008 - 08:08 AM
QUOTE (SeanK @ Sep 16 2008, 12:03 PM) <{POST_SNAPBACK}>
Hi to All,
Seank
Seank
Dear,
The compressor surge curve is used by HYSYS to introduce disturbances in the compressor if the flow drops below the surge limit. This is not the curve used for predicting the Surge Flow for the Surge Controller.For more information about how the Surge Controller works see the HYSYS Dynamic Modeling Manual. Or the following solutions, found under the Process Controllers and Logical Ops category in Apsen Tech Support Website. The Solution Id Numbers are
1. What is a Compressor Surge Controller? (Solution 109042)
2. How do I create a Surge Controller in HYSYS? (Solution 115317) What are the Surge Parameters of the Compressor Surge Controller? (Solution 109040)
Posted 18 September 2008 - 12:20 AM
Dear Padmakar,
Thanks indeed for the reply with adequate information, actually could you please let me know from where i can get the hysys dynamic manual, any links please
Thanks for the help
regards
Sean
Dear,
Thanks for the help
regards
Sean
QUOTE (Padmakar S Katre @ Sep 17 2008, 09:08 AM) <{POST_SNAPBACK}>
Hi to All,
Seank
Seank
Dear,
Posted 18 September 2008 - 10:21 AM
QUOTE (SeanK @ Sep 17 2008, 11:20 PM) <{POST_SNAPBACK}>
From your AspenTech rep or via support.aspentech.com
Posted 18 September 2008 - 11:34 PM
QUOTE (joerd @ Sep 18 2008, 11:21 AM) <{POST_SNAPBACK}>
Thanks for the reply
Sean
Posted 22 September 2008 - 07:36 AM
Dear Padmakar,
Could you please let me know how can i calculate the surge flow rate in HYSYS
Posted 24 September 2008 - 01:54 AM
Dear Seank:
Pls note that the surge line is normally provided by the compressor vendor, not calculated by client. With the help of vendor, you can regress the surge line according to the requirement of surge controller settings of Hysys. The ASC parameters should be correctly set based on different version of Hysys. The equation used for surge line is different between Hysys 3.2/Hysys 2004+. For details pls refer to the hysys dynamic manual.
Dynamic simulation is more preferred for Compressor surge analysis. Studied cases should be decided before simulation depending on what is the purpose of your surge analysis. Normally for ASV sizing, coast down trip of compressor should be simulated.
Posted 30 September 2008 - 08:21 AM
QUOTE (verylazybird @ Sep 24 2008, 12:24 PM) <{POST_SNAPBACK}>
Dear Seank:
Dear,
I totally agree with your recommandations.
Importing Component Stream Data From Hysys To Excel Using VbaStarted by Guest_TimL_* , 17 Aug 2018 |
Sulfuric Acid Plant Aspen Hysys HelpStarted by Guest_kazuki222_* , 29 Apr 2026 |
Energy Analysis In Aspen Plus 14.2Started by Guest_Sarishma_* , 23 Mar 2026 |
