I am currently an undergrad student doing a design project involving cleaning of coals. In the process, it is favourable to separate a combined stream containing aqeuous fluosilicic acid H2SiF6, hydrogen fluoride HF and water. The separated HF will then be recycled and redirected back to the process.
I am stuck in a predicament to separate a combined stream containing aqeuous fluosilicic acid H2SiF6, hydrogen fluoride HF and water. From my research, it is discovered that this mixture is a ternary azeotrope. There is no known information on how to size or design a distillation column for this kind of mixture.
Will anyone be able to help/direct me to any form of useful resources or advice to separate and design the process? Other methods besides distillation are also welcome for discussion.
Thanks in advance,
Justin
Ternary Azeotropic Distillation Design
Started by justinmicoud, Sep 16 2008 01:50 AM
No replies to this topic
Posted 16 September 2008 - 01:50 AM
![]() Wet Scrubber Design For Low Flow Rate Of GasStarted by Guest_SIVAMOORTHY_* , 17 Apr 2018 |
Rupture Disk Tail/lateral Piping Design BasisStarted by Guest_Karthikram_* , 19 Aug 2025 |
![]() ![]() Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
