Why is ethanol injected into gas compressors?
Gas Compressors
Started by , Sep 25 2008 07:44 PM
Posted 25 September 2008 - 07:44 PM
Posted 25 September 2008 - 11:06 PM
QUOTE (hydraulichybrid @ Sep 26 2008, 04:44 AM) <{POST_SNAPBACK}>
Probably to ensure no trace of moisture enters the compressor. Am i right?
Narayanan
Posted 26 September 2008 - 06:06 AM
Narayanan:
Why is it that you guess that ethanol (or any other alcohol) would prevent water from entering a gas compressor?
What gives ethanol the ability to bar water from flowing into a compressor?
I think what you mean to say is that ethanol might prevent the formation of methane or other hydrocarbon hydrates. Is that correct? However, if that were so, the water would still exist in the system - but not as part of a hydrate crystal.
Posted 26 September 2008 - 06:42 AM
Normally methanol or glycol are used as hydrate inhibitors, not ethanol.
Posted 26 September 2008 - 11:25 AM
You are absolutely right Guido.
However, some engineers who have a lot of ethanol around (like those in Petrobras - Brasil) like to use ethanol instead due to the local economy. Ethanol also inhibits hydrate formation - and less of it is wasted in the vapor phase since its vapor pressure is lower than that of methanol.
I'm still curious about the basis for the question raised. I wouldn't inject any thing other than the process gas into the suction of a centrifugal compressor if I could help it. However, there are some strange applications out there......
I hope the O.P. responds with some detailed data and explanation(s) for the question.
Posted 01 October 2008 - 09:35 AM
Everybody is right; an alcohol injection will inhibit the hydrate formation.
A hydrate is a physical combination of water and organic molecules with a crystalline structure resembling ice, but different than ice.
An essential condition for a hydrate formation is to have the gas at or below the water dew point, or saturation condition. Hydrates do not form if water is vaporized.
The alcohol, having a higher volatility will decrease the water dew point of the gas. In other words the hydrate will form at lower temperatures than your normal operating.
Water is still present in the gas stream but in vapor form, and is maintained in vapor phase by partial pressure effect of the vaporized alcohol.
In most of the areas methanol or glycols are used as hydrate inhibitors. Ethanol I would expect to have a lower dosage need, since has a higher volatility.
Posted 05 October 2008 - 01:13 AM
Interesting topic. According to many experiments and field experience, hydrates can form even in the case when water content of a gas is below saturation point at given pressure and temperature, and definitely they can form if only water vapor is present in the system.
Hydrate formation kinetics is also an important thing to be considered since reaction is highly time-dependent. A perfect example is the use of Twister technology for gas dew-pointing and dehydration: many applications worldwide are showing that hydrates cannot be formed even at conditions which are well below hydrate formation point - if gas velocity approaches sonic velocity, like it is the case in Twister tubes.
There are many publications about hydrates available on the internet, Gas Liquids Engineering website is one of good starting points. Still, what is not clar in this thread is the purpose of ethanol injection in compressor suction. Like Art said, injecting liquid in compressor suction - unless one is 100% sure that liquid will vaporize before it reaches compressor internals - is potential hazard and very dangerous situation.
![]() Constant Volume Vs Constant Mass Flow Of Centrifugal CompressorsStarted by Guest_panoska_* , 18 Nov 2024 |
![]() Centrifugal Compressors (Actual Vs Polytropic Head)Started by Guest_panoska_* , 25 Oct 2024 |
![]() Spillback In Centrifugal CompressorsStarted by Guest_Venkat @89_* , 14 Jun 2024 |
![]() General Balance Of Energy On Compressors, QuestionStarted by Guest_MumtazDogan_* , 29 Apr 2024 |
![]() Fan Laws For Centrifugal Compressors And Varying Suction ConditionsStarted by Guest_SickPuppy0_* , 25 Jan 2023 |
