How can I calculate gas flow through a control valve from it's opening, when pressure and all other operating parameters are normal.
Best regards.
Flow Calculation From Valve Opening
Started by aanita, Nov 02 2008 11:51 AM
Posted 02 November 2008 - 11:51 AM
Posted 03 November 2008 - 01:03 AM
Your valve supplier will be able to provide you with either a graph or table that correlates the valve's opening with its effective Cv. This curve is known as the valve's characteristic curve. This will allow you to calculate the Cv for the known opening. And once you have the Cv you simply use the standard valve sizing formula to calculate the flow.
I have done this myself and it does give a good indication of flow, but be aware that the characteristic curves are fairly generic and it can be difficult to read the valve opening exactly, so you will get limited accuracy.
Posted 03 November 2008 - 04:14 AM
QUOTE (katmar @ Nov 3 2008, 10:03 AM) <{POST_SNAPBACK}>
Thankyou very much for your time.
Posted 03 November 2008 - 08:51 AM
Two very useful free resources:
http://www.emersonpr...umentation.html
http://www.emersonpr...tvuesizing.html
In Fisher Control Valve Handbook you can find the "Fisher Formula" pretty much a standard for pressure drops/flow calcs across valves.
Posted 03 November 2008 - 10:18 AM
In my opinion, Crane's Technical Paper No. 410 is a reference that should be on every engineer's desk that does fluid flow calculations. It is concise, yet handles the basics thoroughly. While it may not have all the information to solve your problem, it will give you an understanding of what you need and how to use it. It's available for purchase on the internet for a very modest fee in an English or SI version. Google it.
Posted 03 November 2008 - 12:18 PM
QUOTE (latexman @ Nov 3 2008, 08:18 PM) <{POST_SNAPBACK}>
Just a general comment, I think almost all
for neeful consulting reference.
Best regards
Qalander
Teg Dehydration Stripping Gas Flow RateStarted by Guest_SidRah_* , 20 Aug 2025 |
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
