QUOTE (fallah @ Dec 20 2008, 03:16 PM) <{POST_SNAPBACK}>
QUOTE (sheiko @ Dec 19 2008, 04:40 PM) <{POST_SNAPBACK}>
QUOTE (fallah @ Dec 19 2008, 07:02 PM) <{POST_SNAPBACK}>
QUOTE (sheiko @ Dec 18 2008, 06:15 PM) <{POST_SNAPBACK}>
However, considering that, the head developped by the pump and the head required by the system both include the pressure head terms of source and destination drums, i thought the effect of superimposed pressure would cancel when differentiating the heads. No? I hope my description is clear enough
In a stable pumping system:
Developed head by the pump=(superimposed discharge pressure-superimposed suction pressure)+(velocity head in discharge line-velocity head in suction line)+(static head of discharge line-static head of suction line)+(hydraulic loss in suction line+hydraulic loss in discharge line)
1/ What do you mean by "stable pumping system"?
2/ I rather think what you describe is the system head
1-"stable pumping system"?is a system that could be considered dinamically stable without any considerable change in its main characteristics such as pump RPM,flowrate,pressure heads,....
2-What i described is an equation relates developed head by the pump to system head....
Dear sheiko
I understand fallah in his last post had very correctly/ appreciably put the whole in equation form.
Qalander
