Here is the knowns
mass flow for Cold fluid =3621.197 Lbm/hr Variable simple (mc) c is subscribt for cold
mass flow for Hot fluid=2218.512 Lbm/hr Variable simple (mh) h is subscribt for hot
Specific Heat flow for Cold fluid = 1.00 BTU/Lbm/F Variable simple (Cc) c is subscribt for cold
Specific Heat flow for Hot fluid = 0.527 BTU/Lbm/F Variable simple (Ch) h is subscribt for cold
Overall heat transfer cofficient = 15.385 BTU/hr.ft^2.F Variable simple is (Uo)
Temperature for (inlet) entering Cold fluid = 60 F
Temperature for (inlet) entering Hot fluid = 200 F
Temp. for Outlet Cold fluid = ??
Temp. for Outlet Hot fluid = ??
thanks a lot for your help
P.s. there is a picture of the heat exchanger attached
