Flow Reversibility In Shell And Tubes Heat Exchangers
No replies to this topic
#1 GREGORY
GREGORY
  • 12 posts
Posted 26 November 2008 - 09:22 AM
Dear all,
The relation : Preversed(R, NTU)=P(-R,NTU)/[1+RP(-R,NTU)] give the thermal effectiveness of a heat exchanger (defined by P, R and NTU) when you reverse the flow of one of the two fluids. I know that this relation is valid if thermal properties are temperature independent and one of the flow is mixed.
My question is : is this relation still valid in the case of multi-passes on both sides (sheel side and tube side)?
Thanks in advance.
Gregory
