Does anyone have any information of the solubility of CO2 in ethanol at various temperatures, or where I might find such information?
Solubility Of Co2 In Ethanol
Started by boss429jc, Dec 12 2008 10:04 AM
Posted 12 December 2008 - 10:04 AM
Posted 19 December 2008 - 12:45 AM
The supercritical method for biodiesel production is critically examined. Operating conditions such as alcohol type, stoichiometry, temperature, pressure, and the presence of a catalyst and/or co-solvent are examined. The supercritical method is tolerant towards feedstocks containing large amounts of moisture and free fatty acids. High yields of methyl esters are obtained by using high alcohol ratios with high temperatures and pressures. The supercritical method is catalyst free and simplifies the recovery of glycerin as a co-product for biodiesel production. Some questions are posed, as this method is relatively new in the area of biodiesel fuel production.
Posted 23 December 2008 - 04:38 AM
You also forgot to mention that gasoline can be shipped via pipelines from where it is drilled to a central distribution center whereas ethanol cannot be piped and must be carried by truck from the farmland to the distillery and from the distillery to the gasoline mixing station.
Reduce Carbon
Reduce Carbon
Handheld Ethanol Fuel Content AnalyzerStarted by Guest_Sciosophy_* , 03 Mar 2026 |
Sugar Impurities After Distilling Ethanol FuelStarted by Guest_vyse_* , 14 Nov 2024 |
Simulating Solubility Of Ammonia Gas In WaterStarted by Guest_abdullahq7_* , 30 Jan 2024 |
Chemical Reaction Ethanol And CwfiStarted by Guest_Fuentes487_* , 01 Nov 2022 |
Quaternary System Solubility (Nacl-Mgcl2-Kcl-H2O) (Nacl Solution MininStarted by Guest_jordan1111_* , 10 Jun 2022 |
