Binary Interaction Parameters
#1 satsat
satsat
Posted 07 January 2009 - 01:00 PM
I need to use Binary Interaction Parameters for Wilson property package in Hysys Micro Language Editor.
I need your help for my classroom project.
Some thing like:
------ 276.756
975.486 ----
Aij for H2O-Ethanol
Source code like :
?? = ?? WilsonPropPkg.Aij .??
Waiting for your kind help
Please help me
#2 Padmakar Katre
Padmakar Katre
  • 992 posts
Posted 12 January 2009 - 08:13 AM
Dear,
Could you give the further details of your problem as it is hard to interprete from your post.
#3 joerd
joerd
  • 371 posts
Posted 12 January 2009 - 11:59 AM
QUOTE (satsat @ Jan 7 2009, 11:00 AM) <{POST_SNAPBACK}>
I don't know the Hysys macro language editor very well - it is not very userfriendly IMHO - but here is the VBA code to retrieve the Aij values. You can probably adapt it to suit your situation.
CODE
Sub GetAij()
Const hyEMPTY As Integer = -32767
Dim h As HYSYS.Application
Dim s As SimulationCase
Dim fp As FluidPackage
Dim wp As WilsonPropPkg
Dim a As Variant
Dim nc As Integer, i As Integer, j As Integer
'Link to the open HYSYS case
Set h = GetObject(, "HYSYS.Application")
Set s = h.ActiveDocument
'Link to the desired fluid package (here named "Basis-1)
Set fp = s.BasisManager.FluidPackages("Basis-1")
Set wp = fp.PropertyPackage
'Get the number of components
nc = fp.Components.Count
'Get the Aij parameter values as a two-dimensional array of dimension nc,nc
a = wp.Aij.GetValues("")
'Print the values, display nice --- instead of <empty> value (-32767)
For i = 0 To nc - 1
For j = 0 To nc - 1
If CInt(a(i, j)) = hyEMPTY Then
Debug.Print "---",
Else
Debug.Print a(i, j),
End If
Next j
Debug.Print
Next i
End Sub
#4 satsat
satsat
Posted 15 January 2009 - 03:00 AM
Dear joerd
Thank you
it solved my problem
