Pressure/flow Relationship For Air
Started by gracehealy, Feb 12 2009 01:47 PM
Posted 12 February 2009 - 01:47 PM
If I know that my compressed air pipe is 0.5" and I know that the pressure of the air is at 1bar, is there any way of calculating what the flowrate of the air is in the pipe without a flowmeter?
Posted 12 February 2009 - 02:15 PM
If you know what is the pressure drop between two points, then you can calculate it (or at least estimate it). By knowing only the source pressure, there is infinite number of solutions.
Posted 20 February 2009 - 10:47 PM
No, you can't...you need to know at least the differential pressure
Posted 23 February 2009 - 03:20 AM
Do you want to estimate how much air flow is passing through this line OR you want to estimate how much maximum flow is possible in this line.
Posted 25 June 2010 - 03:12 AM
Agree, But Any one can forward a formula if there's a pressure at downstream, such as 0.9 bar?
Posted 25 June 2010 - 10:53 AM
Biz:
Please answer Pawan's basic and direct question: "Do you want to estimate how much air flow is passing through this line OR do you want to estimate how much maximum flow is possible in this line?"
What you have responded with is an agreement to the question! That doesn't make any engineering sense. What Pawan is asking is very basic and deserves a positive response. Please be candid and inform the Forum of WHAT exactly it is that you are trying to do or to ask. We can help you, but you must be specific as to your query.
Posted 26 June 2010 - 07:21 AM
You must be knowing inlet pressure of Compressor (Mostly atmospheric).
You can find out the flow from compressor curve using RPM and ∆P across it.
