Hello Everybody,
I am trying to use hierarchy blocks for a complex simulation in aspen plus. Currently i have divided process in 4 different simulations since i wanted to use different thermodynamic properties for different section. Now i want to have these pieces of simlations into single main flowsheet. I can use hierarchy and sectioning the flowsheet. My problem is how to connect different sections if i have different stream class (i can use mixer and cichange. but cichange is giving mass balance error). also how can i check in results which thermodynamic properties have been used for different sections.(just to make sure each block is using specified thermodynamic properties). What happens to a stream when it goes from one section to other and changes its thermodynamic basis.
Hierarchy Blocks And Thermodynaics Aspen Plus
Started by chemluv, Feb 12 2009 02:43 PM
No replies to this topic
Posted 12 February 2009 - 02:43 PM
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
No Liquid Phase In Aspen PlusStarted by Guest_PengRobinson_* , 09 Feb 2025 |
![]() Help On Simulation Of Reactor In Aspen PlusStarted by Guest_m.ghaziasgar_* , 06 Jan 2025 |
