Maximum Design Temp. Of Flare Header
10 replies to this topic
#1 process12
process12
  • 7 posts
Posted 22 February 2009 - 05:32 AM
Dear All
In Fire case when relief temperature is subject to reach up to 400°C shall be selected this value as Design temperature of tail pipe, Flare Header and K.O Drum?
Tanks a lot
#2 fallah
  • 5,019 posts
Posted 22 February 2009 - 05:57 AM
QUOTE (Mohamad Hasan @ Feb 22 2009, 05:32 AM) <{POST_SNAPBACK}>
Dear All
Tanks a lot
The maximum design temperature of the equipment and its piping connection to flare system (header,K.O. Drum,...) wouldn't be determined based on fire case.
#3 jprocess
jprocess
  • 316 posts
Posted 25 February 2009 - 01:23 AM
QUOTE
Do you know any statement in relevant codes, standards or papers on this subject?
#4 Qalander (Chem)
Qalander (Chem)
  • 829 posts
Posted 25 February 2009 - 02:43 AM
QUOTE (jprocess @ Feb 25 2009, 11:23 AM) <{POST_SNAPBACK}>
QUOTE
Dear Mojtaba Habibi,
I understand that you should get useful info on this through
'NFPA glossary of terms'
this probably should already be with you and is also accessable through nfpa/nec website(s)
I also posted sometime back through this very forum as an attachment.
Any help will be provided with pleasure.
Best Regards
Qalander
#5 fallah
  • 5,019 posts
Posted 25 February 2009 - 02:51 AM
QUOTE (jprocess @ Feb 25 2009, 02:23 AM) <{POST_SNAPBACK}>
QUOTE
As an example: Process Sizing Criteria by TOTAL included the notes very close to above statement.
#6 Qalander (Chem)
Qalander (Chem)
  • 829 posts
Posted 25 February 2009 - 03:13 AM
QUOTE (fallah @ Feb 25 2009, 12:51 PM) <{POST_SNAPBACK}>
QUOTE
Dear All, Basically this is a part of "Good Engineering Practices"
Probably by all major designers/ stakeholders, Process safety implementing organisations etc.
You should be possible to find at iternet if Googled through these key words
Best Regards
Qalander
#7 fallah
  • 5,019 posts
Posted 25 February 2009 - 05:34 AM
QUOTE (Qalander (Chem) @ Feb 25 2009, 04:13 AM) <{POST_SNAPBACK}>
Which key words?
#8 jprocess
jprocess
  • 316 posts
Posted 28 February 2009 - 06:02 AM
QUOTE (Qalander (Chem) @ Feb 25 2009, 03:43 AM) <{POST_SNAPBACK}>
QUOTE
Best Regards
Qalander
Dear Qalandar,
Is it possible for you to upload here the specific part which speak about ignoring fire temperatures?
#9 jprocess
jprocess
  • 316 posts
Posted 28 February 2009 - 06:04 AM
QUOTE (fallah @ Feb 25 2009, 03:51 AM) <{POST_SNAPBACK}>
QUOTE
I did some review but could not find anything whithin Total docs. Could you please write here the mentioned statement?
#10 fallah
  • 5,019 posts
Posted 01 March 2009 - 02:14 AM
QUOTE (jprocess @ Feb 28 2009, 07:04 AM) <{POST_SNAPBACK}>
5.2.5 The exceptional temperature generated by fire will not be considered to specify the design
temperature selection.
#11 Qalander (Chem)
Qalander (Chem)
  • 829 posts
Posted 01 March 2009 - 04:42 AM
QUOTE (fallah @ Mar 1 2009, 12:14 PM) <{POST_SNAPBACK}>
fallah's above clarification should suffice as an answer to the OP's query
on relieving system/piping temperature designing;never on the fire case in general.
Moreover we must keep in mind that Piping and system should and most usually does take care of
'Most Prevalent' Weather and/or process environment, conditions related point high and low temperatures.,
I hope this is helpful in general.
Best regards
Qalander
