Dear all
I begun to calculate the overall heta transfer for WHR boiler . I pose to perceive what are the critical factor to be taken into consideration while calc the same . Notebly the heat transfer is shell and tube type and medium is fluegas and organic fluid
Thanks for being so understanding.
MONTEK
Overall Heat Transfer
Started by chau, Feb 23 2009 12:04 AM
Posted 23 February 2009 - 12:04 AM
Posted 23 February 2009 - 05:51 AM
can you put more info on process steam type or composition ? are these fouling ? process pressure / temperatures ?
also TEMA type of your Whb
cheers,
sm
cheers,
sm
Posted 23 February 2009 - 06:00 AM
QUOTE (smalawi @ Feb 23 2009, 05:51 AM) <{POST_SNAPBACK}>
cheers,
sm
cheers,
sm
Dear sir
Thanks for your generosity
Input Data of flue gas
1) Flue Gas SOURCE-1(PRE-HEATER) SOURCE-2(COOLER OUTLET)
Flow 259701 Nm3 / Hr 159619 Nm3 / Hr
Inlet Temperature 324 Deg C 382 Deg C
(to boiler)
Dust content 12 g/m3 15g/m3
Above is the input data of flue gas to boiler , as there is two source point of heat in cement plant. I had complied the operating parameter of same
As inquired by you for TEMA design , lets be frank i dont know the significance of using TEMA in boiler. Kindly enlighten me about the same
Objectively we may use the organic fluid. Decisively the operating parameter will be normal , since the generation is of 2MW Power.
Taking above in consideration , kindly have me your response
MONTEK
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
How To Estimate The Water Dewpoint From Heat And Mass Balance Of NaturStarted by Guest_krishnnaa26_* , 30 Apr 2026 |
Waste Heat BoilerStarted by Guest_Prim_* , 25 Apr 2026 |
