I want to depressurize manually a flowline to I atm having liquid at design pressure of 138 barg and at a min temperature of 250C.
That particular stream bubble point was found in Envelop utility is 60 barg.
As per my knowledge the pressure reaches from 138 barg to 60 barg will be in the form of liquid. Hence if I open blow down valve manually till 60 barg only liquid should come out. Then from 60 barg to 1 atm full of vapor will come out.
If I do this in Depressurisation Dynamics Utility, I am getting only vapor at the outlet.
More offer, if I do flashing from 138 barg to 60 barg with a help of a valve , I am getting a vapor fraction of 0.246.
Depressurising time may be taken as 60 min.
Any other method is there, to do the exact depressurization study.
M.Murali
Manual Depressurisation
Started by muralimuthu, Mar 05 2009 05:11 AM
![]() Manual Depressurisation - How To Determine Restriction Orifice SizeStarted by Guest_FUNMILAYO_* , 14 Oct 2020 |
Manual Creating New Component And Setting Properties In HysysStarted by Guest_Platonicus_* , 15 Mar 2023 |
![]() Tank Depressurisation Through Vent Pipe CalculationStarted by Guest_lambonumber5_* , 08 Apr 2021 |
Manual DepressurizationStarted by Guest_Danish John Paul_* , 04 Jun 2021 |
Manual Transfer From Barrel To ContainerStarted by Guest_kangas_* , 02 Jun 2021 |
