Does anyone have any experience with putting in steam-turbines to reclaim heat generated during your process?
The plant I work at mainly handles solids. On each of our units we have an afterbuner to destroy the organics that we remove. We generally want to remove heat from the process rather than preheat incoming solids/gases, so HX to preheat isn't useful. We do have a boiler, but hopefully we won't be using it all in about 2 weeks (replacing/upgrading).
I was trying to think of a way to recover all this wasted heat. I have no experience with generating electricty through steam turbines, though. I don't know if we even generate enough heat to make it worth it, or if they make turbines small enough.
We have 2 afterburners that usually operat ~850 C plus one that operates ~500C, ATM pressure, with 2500 SCFM per burner. Does anyone have any advice, experience, or literature resources that could help me determine if the money saved generating electricity would be worth the cost of all the equipment?
Thank you.
Reducing Elec Consumption With Turbine
Started by UT_BKC, Mar 17 2009 11:04 PM
Posted 17 March 2009 - 11:04 PM
Posted 23 July 2009 - 02:34 AM
Basically your waste heat can be used as power generated,but your waste heat should be converted to steam (let say 24 barg steam saturated). How to convert waste heat to steam,? at top of furnace you must install economizer for absorp heat and generate steam. function of Process waste heat same as boiler unit. If steam already there, steam can be used as power generation via steam-turbine.
Goodluck
Asep
Air Consumption For On Off ValvesStarted by Guest_itsmetinnie_* , 11 Mar 2024 |
Self Actuated Pressure Reducing ValveStarted by Guest_panagiotis_* , 16 Feb 2024 |
Reducing Steam Consumption In Vacuum Packed DistillationStarted by Guest_dpunnn_* , 30 Nov 2023 |
Energy Consumption CalculationStarted by Guest_seuenergy_* , 16 May 2023 |
Hydrogen Consumption In Water Gas Shift ReactorStarted by Guest_afshinli_* , 20 Dec 2022 |
