we are designing a floating LNG facility (1.5 Mtpa LNG production) for our design project and we have encounter some problem in doing material and energy balance for amine process.
For your information, we are using amine base solvent of DEA for this process, but we cannot find the suitable composition and flowrate of lean amine. Can you please help me to find them?
Thank you very much for your attention.
Amine Process
Started by izz, Mar 19 2009 12:29 PM
Posted 19 March 2009 - 12:29 PM
Posted 20 March 2009 - 10:35 AM
Hi IZZ:
There are several equations give in GPSA engineering book. which can help you in determining the amine flow rate. As you mentioned that you are using DEA.
The following equation will apply in order to find out the Flow rate for DEA
GPM= 45*(Q*y/x)
Q= Feed gas flow rate (MMscfd)
y=acid gas concentration in feed gas
x=concentration of amine in liquid solution
I hope this help you.
GPM= 45*(Q*y/x)
Going Through The Writing Process.Started by Guest_Haywardvek_* , 05 Jan 2025 |
Typical Process Of Platformate Splitter ?Started by Guest_AnbIran_* , 30 Dec 2024 |
![]() Process Gas Compressor - Capacity Control ValveStarted by Guest_CHSO4_* , 18 Jul 2024 |
![]() Amine(Mdea) StorageStarted by Guest_abdullah1320_* , 17 Jun 2024 |
