Hydrocarbon Mixture Dewpoint
9 replies to this topic
#1 siddiqsh
siddiqsh
  • 7 posts
Posted 13 April 2009 - 11:55 PM
I need to calculate dewpoint of hydrocarbon mixture having ethane 5%, ethylene 30%, hexane 3% and rest nitrogen 62%(mole fraction). pressure 24 kg/cm²g, temperature 85°C. please give me steps for calculating dewpoint
#2 mrj
mrj
  • 18 posts
Posted 14 April 2009 - 12:35 AM
Dew Point is 49.18 Deg C; i have used a simulator for this calculation.
#3 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 14 April 2009 - 08:57 AM
Siddiqsh,
Check out this on-line calculator:
http://www2.questcon...rmo/dewbub.html
Seems to be fairly good.
#4 clarenceyue
clarenceyue
  • 46 posts
Posted 14 April 2009 - 10:06 PM
Hi Siddiqsh,
You may like to try it by hand using the classic DePriester Charts. It may be approximate, but I really recommend that you try it by hand.
I have attached two diagrams for your reference.
Have fun!
Attached File  DePriester_Chart_High_T_SI.pdf   1015.72KB   152 downloads
Attached File  DePriester_Chart_low_T_SI_units.pdf   592.19KB   96 downloads
#5 siddiqsh
siddiqsh
  • 7 posts
Posted 19 April 2009 - 05:51 AM
thanks for your time.
I am looking for some method for calculating dewpoint using some equations.
#6 luuquocdai
luuquocdai
  • 48 posts
Posted 19 April 2009 - 08:27 AM
Please repeat this equations to get the result.
Best regards.
LuuQuocDai
luuquocdai@gmail.com
#7 siddiqsh
siddiqsh
  • 7 posts
Posted 19 April 2009 - 09:37 PM
QUOTE (luuquocdai @ Apr 19 2009, 04:27 PM) <{POST_SNAPBACK}>
Best regards.
LuuQuocDai
how do i get Ki values using equation of state.
#8 clarenceyue
clarenceyue
  • 46 posts
Posted 19 April 2009 - 10:22 PM
dear siddiqsh,
please look up the chapter dealing with non-ideal VLE in any standard chemical engineering thermodynamics textbook, like Van Ness et. al. for example.
i think you'd learn alot more if you actually went to the library and do some looking up before coming here asking to be spoon-fed.
clarence
#9 breizh
  • 6,769 posts
Posted 19 April 2009 - 11:30 PM
If I'm right you can found all the info in Process heat transfer from KERN and Perry's chemical handbook.
#10 luuquocdai
luuquocdai
  • 48 posts
Posted 20 April 2009 - 05:32 AM
You can find the value of Ki in Gas Conditioning and Processing of John Campbell
If you have any question about this problem, please contact or reply as soon as possible.
Best regards.
LuuQuocDai
