Hi all,
I have queries regarding the usage of seal plans in vertical sump pump i.e., VS4 type. Vendor recommends non contacting dual mechanical seal with plans 02 and 61. Also recommends not to use flushing plan. Service is hydrocarbon.
i) Pls explain how this dual seal work with the above mentioned seal plans as both plan 02 and 61 usually used with single seals????
ii) Whether fluid will flow to the outboard seal i.e., plan 61 and how the outboard seal will be cooled??????
Eagerly waiting for you replies.....
Seal Plans In Vertical Sump Pump
Started by PKSK, Apr 14 2009 04:07 AM
No replies to this topic
Posted 14 April 2009 - 04:07 AM
Pump Selection ProblemsStarted by Guest_kito-818_* , 14 Nov 2025 |
The Centrifugal PumpStarted by Guest_guoyinyanliner_* , 15 Dec 2025 |
Velocity In A Vertical Pipe Or Open PipeStarted by Guest_jango_* , 02 Dec 2025 |
