I am doing depressuring calcualtions for gas oil sepration, I want reference for calculating depressuring rates, and any reference regarding HYSYS simulation for dynamic depressurization kindly also post if any body have chapter 14 of HYSYS operation guide.
Depressurization Rates
Started by Subramaniam K, Apr 23 2009 09:18 PM
Posted 23 April 2009 - 09:18 PM
Posted 24 April 2009 - 04:21 PM
QUOTE (Subramaniam K @ Apr 24 2009, 04:18 AM) <{POST_SNAPBACK}>
Go to this blog: http://webwormcpt.blogspot.com/ and use the search feature. There are plenty of very good info. about depressurization and Hysys namely.
Posted 26 April 2009 - 04:43 AM
See attached Dynamic Depressuring Utility User's Guide: "Depressurisation: A Practical Guide" for using the Hysys dynamic depressuring utility.
For more discussion on this topic we need to know system you intend to depressurise like equipment or pipeline since both have different depressuring philosophy.
The equipment requires depressuring for both fire case and during a process requirement like equipment shutdown.
Criteria applied is based on API 521 recommendations, which states to reduce the equipment pressure from initial conditions to 50%of the vessel design pressure within 15 mins. This generally applies to carbon steel vessels with thickness greater than 1". For smaller thickness vessels 15 mins. criteria is not applicable and will require faster depressuring.
Emergency depressuring during fire case is generally applied to vessels operating at higher than 250 psi pressure. In such cases depressuring to 690 kPa is done.
Depressuring a pipeline or a section of pipeline is done for process reasons / maintenance requirements. Due to large inventories of long pipeline, depressuring is achieved over several hours.
Apart from the requirement of final pressure and depressuring time, there are other areas which a designer should look into while sizing a RO on the downstream of a blowdown valve such as
- negative temperature as the gas cools by expansion
- peak depressuring rate is less than or equal to the flare capacity
- An equipment like compressor can have multiple blowdown valves at the downstream of each stage.
Best Regards,
Joyy
Best Regards,
Joyy
Posted 26 April 2009 - 09:28 PM
Thanks for ur replies and useful references.
Can u provide me a detailed calculations steps for depressuring rates like formula to calculate initial depressuring rates as the rate is maximum during first few seconds of depressurization.
![]() Hydrogen Storage Tank Depressurization Duration - For Maintenance!Started by Guest_panagiotis_e_* , 11 Jul 2024 |
![]() Rapid Depressurization Of WaterStarted by Guest_Gole_* , 31 Mar 2024 |
Depressurization SystemsStarted by Guest_VIrendra20911_* , 02 Nov 2022 |
Pro Ii - Adjusting Std Flow RatesStarted by Guest_lsoaresfernandes_* , 26 Oct 2021 |
Manual DepressurizationStarted by Guest_Danish John Paul_* , 04 Jun 2021 |
