How To Convert Demulsifier/caustic/philmplus Rate In Ppm?
#1 naimatullah84
naimatullah84
Posted 26 April 2009 - 06:33 AM
hi,
i am a trainee operator in a refinery. please tell me how we covert the demulsifier/caustic/philmplus flow rate in ppm.
  • 6,786 posts
Posted 27 April 2009 - 05:08 AM
hello ,
You need to help us and define your query in detail . PPM stands part per million (1e-06) . PPM could be gram/ ton or gram/h / ton/h in case of mass flowrate.
Hope it helps.
#3 naimatullah84
naimatullah84
Posted 04 May 2009 - 11:02 AM
[quote name='breizh' date='Apr 27 2009, 03:08 PM' post='28692']
hello ,
Thanks breizh
I want to inject demulsifier @ 3-5 ppm of crude feed.
How can i calculate and regulate the correct amoumt of chemical injection in crude during my shift duty.
Please explain it briefly.
#4 djack77494
djack77494
  • 1,282 posts
Posted 05 May 2009 - 08:21 AM
Taking ppm to mean mass related, as I think is the common usage for this type of application, you must first convert your crude feedrate into a mass flowrate. So if you have a crude feedrate in say barrels per day (BPD) and you know its density (degrees API), then you must convert that volumetric flowrate * density to a mass flowrate. If you also have a flowrate and concentration for the demulsifier, then you get the mass flowrate of the demulsifier by multiplying the solution (mixture) flowrate * mass fraction of demulsifier in the mixture.
Though this would be considered a very simple calcaulation for a degreed chemical engineer, still it is rather difficult to describe in words. What makes it especially difficult is the fact that I'm given no information about any of the important flowrates or concentrations or densities. So I must address this in the most general way possible. While making my task very difficult, the value of the response is greatly decreased by the need to talk in generalities. For a better quality response, please fully define your system and the key variables. BTW, your best response might well be to talk to one of your plant engineers about this problem and seek his/her help.
