Hydraulic Radius Of Partially Filled Circular Conduits
9 replies to this topic
#1 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 20 May 2009 - 08:38 AM
The Manning equation is extensively used for cold water hydraulic calculations and the equation expressed in terms of average velocity is:
v = (1/n)*RH2/3*S1/2
where:
n = Manning coefficient, dimensionless
RH = Hydraulic Radius, m
S = slope of the conduit, m/m
RH is further defined as:
RH = A/P
where:
A = cross-sectional area of the conduit, m2
P = Wetted perimeter of the conduit, m
For a fully filled circular conduit the hydraulic radius RH becomes as follow:
RH = (Pi*D2/4) / Pi*D
which when simplified becomes
RH = D/4
where
D = Internal Diameter of the circular conduit.
This is the background of Manning equation with respect to fully filled circular conduit (pipe). However, the answer I am seeking is how to calculate the hydraulic radius of a partially filled pipe, say for example, 1/4-filled, 1/2-filled and 3/4-filled.
In some reference I found that the hydraulic radius of a partially filled pipe can be calculated by multiplying the diameter D of the pipe with a factor 'F'. The unanswered question is how to find this factor 'F' and is there a calculation method for this factor 'F'.
Any help regarding this query would be appreciated.
  • 6,718 posts
Posted 20 May 2009 - 10:18 PM
Hi Ankur ,
Should support your query.
http://www.ajdesigne...uation_pipe.php
regards
#3 SPOOK
SPOOK
  • 21 posts
Posted 21 May 2009 - 12:55 AM
QUOTE (ankur2061 @ May 20 2009, 07:08 PM) <{POST_SNAPBACK}>
RH = A/P
where:
Ankur,
Find the attached excel sheet which shows how to find the perimeter of the partially filled circular pipe.
Now using this perimeter in the above equation of yours for hydraulic radius you will be able to find the appropriate hydraulic radius.
Hope this info is helpful
SPOOK
#4 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 21 May 2009 - 09:47 AM
QUOTE
regards
Breizh,
Thanks. This is what I was looking for. I converted it into a spreadsheet with inputs as % filling of pipe and internal diameter of the pipe.
#5 TechExpert
TechExpert
  • 74 posts
Posted 21 May 2009 - 10:38 AM
not able to open the file.
QUOTE (SPOOK @ May 21 2009, 01:55 AM) <{POST_SNAPBACK}>
RH = A/P
where:
Ankur,
SPOOK
#6 breizh
  • 6,718 posts
Posted 23 May 2009 - 07:58 PM
Hello Ankur ,
additional information on this site :
http://en.wikipedia....Manning_formula
Go to external link where you can find other shapes :Manning formula calculator for several channel shapes .
#7 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 18 January 2010 - 12:41 PM
Please find attached the spreadsheet for calculating the hydraulic radius for partially filled pipes, which can be used in the 'Manning Equation' for hydraulic calculations of water.
Comments from our members are most welcome.
#8 narendrasony
narendrasony
  • 87 posts
Posted 20 January 2010 - 11:52 AM
Basically the first set of equations (on left hand side in your first sheet) is valid for both the scenarios if you take "h" as the liquid level from bottom for both the cases i.e for h<r as well as for h>r.
#9 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 20 January 2010 - 12:42 PM
Narendra,
The left hand side equation is only valid for filling <50%. For 50% and above the equations on the right hand side are valid. Initially I had done as you have suggested but the results were not correct when I checked with another source.
Hope this clarifies why I have used two sets of equations.
#10 narendrasony
narendrasony
  • 87 posts
Posted 22 January 2010 - 02:59 AM
Ankur,
Please find attached the file with both approaches. Method-1 is with two set of equations, Method-2 is with single set of equations.
Narendra
