OUR NAPHTHA HYDROTREATOR FEED HAS 0.5ppm TO 1.0ppm OF IRON IN IT. FLOW OF NAPHTHA IS 100 USGPM. FEED TEMPERATURE IS AROUND 120F AND DENSITY IS 45 lb/ft3. CAN YOU PLEASE SUGGEST AN IRON REMOVAL FILTER FOR THIS STREAM.
Iron Removal Filter On Hydro Treator Feed
Started by saud, Jun 03 2009 02:38 AM
Posted 03 June 2009 - 02:38 AM
Posted 05 June 2009 - 03:39 AM
QUOTE (saud @ Jun 3 2009, 03:38 AM) <{POST_SNAPBACK}>
Your NHT RX is best Filter to remove these impurities but if you feed pump suction stainer is getting chock frequently then this is matter of concern.
Cheer
Split The Feed Into Two Identical StreamsStarted by Guest_tomr91_* , 16 Mar 2025 |
Effect Of Continuous Blow Down To Boiler Feed WaterStarted by Guest_Dyames027_* , 21 Nov 2024 |
![]() Using Feed Compressor For Start-Up Nitrogen CirculationStarted by Guest_behrouzifar_* , 06 Sep 2024 |
