I am modelling a distillation column in Aspenplus.My column do not have conventional type of Condenser and Reboiler.
Instead , the OVHD vapor stream goes to a Heat pump which compresses the vapor and a part of vapor is used as heating media in the reboiler and get condensed .The remaining part of compressed OVHD vapor get condensed in a cross exchanger with bottoms product (which gets heated and recycled as plant feed).
These two coindensed OVHD product streams again get combined, a part of it goes as reflux and remaining a pure product.
My question is can i use "ABSRB" model(which is for absorption) as my distillation column , because it do not have any prebuilt condenser or reboiler with it. And I can make use of psuedo streams to create a reflux stream.
thanks,
C
Absbr Model In Aspenplus
Started by cmp74, Jun 03 2009 05:56 PM
No replies to this topic
Posted 03 June 2009 - 05:56 PM
Hysys Dynamics Model - Manipulating Split RatioStarted by Guest_OchemWhiz_* , 21 Sep 2024 |
Air Separation Hysys ModelStarted by Guest_akkaset_* , 04 Jun 2024 |
Rate-Based Model DistillationStarted by Guest_panoska_* , 25 May 2024 |
Aspen Custom Model Won't Load Into HysysStarted by Guest_SaintLazarus_* , 21 Mar 2024 |
Issues About Not Converging Of The ModelStarted by Guest_Mohammad3799_* , 06 Feb 2024 |
