actually, i'm working toward the dynamic simulation for refrigeration unit. the system is closed loop and contain three operation unit which is condensor, chiller and compressor. the condensor using cooling water in the tube side while refrigerant at the shell side. chiller using ethylene glycol in the tube side and refrigerant at the shell side. the type of refrigerant used is freon. there is a lot of question i would to ask.
1. what is the suitable fluid package we can use? is it correct to use Activity model?
2. what type of compressor need to use? since, the 186kW being used as a heat supply to the compressor.
3. i would like to make a level transmitter at condensor and also the chiller unit, but i face the problem because the " d_Holdup Level(d_Holdup Level_1d_Holdup Level_1)" for both unit display <empty>. what parameter we need to adjust?
4. another problem, during integrator. i get an error msg about numerical error is occured. what does it mean? is there any case sensitive in condensor and compressor system.
5. i have set the phase for outlet chiller is vapor (which is 1.0000) but why during running simulation the value display for liquid or aques phase? is it we need to specify the flowrate because during dynamic simulation, the specify value for cooling water suddenly dissapear and change to 0.
i hope, there is someone to help me out from this challenge. thank you.
