Dear Sir,
Please explain what was the real requirement of Bleed Ring in the upstream of PSVs and TSVs. Please Explain.
Thanks & regards,
Stu
Bleed Ring In Psv
Started by stu, Jul 03 2009 11:23 PM
Posted 03 July 2009 - 11:23 PM
Posted 07 July 2009 - 06:46 AM
Dear Sir,
Please clear my doubts.
Thanks & regards,
Stu
Thanks & regards,
Stu
Posted 07 July 2009 - 06:59 AM
QUOTE (stu @ Jul 7 2009, 07:46 AM) <{POST_SNAPBACK}>
Dear Sir,
Thanks & regards,
Stu
Thanks & regards,
Stu
Do you mean Blowdown Ring?
Posted 08 July 2009 - 01:19 PM
Bleed rings are frequently used offshore and in situations where space and/or weight may be problems. The bleed ring substitutes for a (very short) pipe spool with a coupling added. Having one would be useful for testing PSV's, including ones for thermal relief, by allowing the applying of a high pressure test gas.
High Vibration Liquid Ring CompressorStarted by Guest_Aziz846_* , 07 May 2023 |
Can You Recycle Edi Electrode Flush And Concentrate Bleed?Started by Guest_J_Leo_* , 14 Feb 2022 |
Double Block & Bleed Valve For Acid Gas LineStarted by Guest_gr8azhar_* , 03 Jun 2019 |
Liquid Ring Vacuum Pump Seal LiquorStarted by Guest_TheChemEng_* , 16 Jan 2019 |
Requirement For Bleed At Psv OutletStarted by Guest_SawsanAli311_* , 04 Dec 2018 |
