I am now having my attachment in a refining company.
I was posted this question by a senior engineer.
For a tray in the distillation column, is the height of the weir important.
There is generally 2 purposes for the weir. One of them is to maintain a certain liquid level on the tray. What is the second one?
Also, the senior engineer did mention that the height of the weir and the distance between the end of the downcomer(from the above tray) and that of the end of the tray are inter-related and play an important and fundamental role in the designing and working of a distillation column. Can someone advice me on what is the importance?
THank you!
Weir Height
Started by conan_kaya, Jul 25 2009 09:57 AM
Posted 25 July 2009 - 09:57 AM
Posted 26 July 2009 - 08:01 AM
Conan,
All the answers can be easily found in any distillation textbook. I bet you can find them just by Google-ing for a few minutes.
The most important purpose of outlet weir is to provide liquid seal, i.e. to ensure that upflowing vapors cannot pass up the downcomer and push the downflowing liquid onto tray above and cause flooding. As long as the height of outlet weir is higher than the downcomer clearance (the distance between the bottom of downcomer and the tray below), there will be a positive liquid seal that prevents reverse flow of liquid inside the tower.
Some special applications (e.g. columns that operate at extremely high liquid rates all the time) can have outlet weir smaller than the downcomer clearance, since high liquid flow itself provides liquid seal (so called "Dynamic seal").
Best regards,
Best regards,
Kettle Reboiler Designe Rules - Position Weir, Height Weir, Liquid LevStarted by Guest_Otthigh94_* , 17 Jan 2024 |
Coulmn Height CalculationStarted by Guest_funkysticks_* , 01 Nov 2023 |
Calculate Packed Height In A Laboratory Distillation SystemStarted by Guest_HOnKung_* , 25 Apr 2023 |
Calculation Of Liquid Seal Height In Reflux LineStarted by Guest_ramshiva_* , 13 Jul 2022 |
Height Of Packed Bed Co2 Stripping ColumnStarted by Guest_MCorray1_* , 30 Mar 2022 |
